Labview Interface for Nuance Dragon Naturally Speaking
We want to control Nuance Dragon Naturally Speaking software (a third party tool to convert Speech to Text) through Labview. Could you please let me know how to interface this tool to Labview? Please suggest us if there are any documents or example explainig this interfacing.
Divya
(2,972 Views)
Does this software have an ActiveX or .NET interface?
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(2,953 Views)
Hi Chris,
Yes, it is having ActiveX controls.
Divya
(2,940 Views)
In that case you should be able to use the ActiveX interface to control the application.  (Functions Pallete >
Connectivity > ActiveX).
Check out this article for some more help: ActiveX and LabVIEW
Do note: This is going to be very dependent on the ActiveX interface for your particular program.  You are unlikely to find a premade VI for this.
Chris
(2,929 Views)
Hi Chris,
Thank you for the information. I will try with ActiveX interface.
Divya
(2,911 Views)
