Labview KEYSIGHT U2702A Control
hi
Can anyone provide the LIB or instructions to control KEYSIGHT U2702A?
At present, only VEE information is available on the KEYSIGHT website.
(3,805 Views)
They proved IVI Driver at:
https://www.keysight.com/us/en/lib/software-detail/driver/u2701a-u2702a-usb-modular-oscilloscope-ivi...
Keysight states you need it for:
"You will need to install the IVI-COM driver to control the U2701A/2702A with Keysight's VEE Pro, NI's LabVIEW, or Microsoft® Visual Studio®."
Take a look at this post too
CLA, CTA
(3,749 Views)
hi LFBaute,
thanks for reply As you mentioned, I have already installed IVI, as shown in the picture below, but I still can’t quote it, so I asked if there are other installation packages?
(3,722 Views)
Accepted by topic author amberchang
Have you tried Chapter 7 of the User Manual?
They suggest this diagram instead of using Constructor node
With the same .NET selection thay you did above, but instead of Constructor Node, you configure it on an "Automation Refnum terminal"
CLA, CTA
(3,712 Views)
hi LFBaute,
I refer to your suggestion, but "ERROR -2147221164" appears during execution, what should I do?
(3,670 Views)
