Labview, My RIO vision assistant
I installed the vision and motion(for my rio) library yesterday and i don't know why  the vision assistant vi is missing.
I have followed the same steps as this guy: yt vision&motion for myRio
Someoane can help me ?
Thank you.
(5,892 Views)
It looks like you installed Vision Acquisition Software (the driver software to acquire images), but not Vision Development Module.
Vision Assistant is part of the Vision Development Module. That's the installer you want to run.
(5,869 Views)
(5,859 Views)
Accepted by Hooovahh
No, it says Vision Common Resources. That's different. The common resources are the components shared between the driver and the Vision library.
You need to download and install this:
https://www.ni.com/en/support/downloads/software-products/download.vision-development-module.html#30...
(5,853 Views)
This is from my Laptop (I don't have Vision installed on a remote system):
(5,845 Views)
It works ! Thank you
(5,832 Views)
How can i make a code that will help me to make 2 usrp 2942R works as a tx and a Rx and to communicate with each other ?
Which block diagram i can add either to the tx or the rx to acomplish that target plz 😊
Thanks on advance
(5,065 Views)
