Labview PDa 8.0.1 can support visa
hi all , can u plz tell me Labview pda 8.0.1 can support modbus serial communication
(3,205 Views)
Unfortunately, you cannot do modbus serial communication with LabVIEW PDA 8.0.1. In oder to do Modbus communication you would need the Modbus Library, but that requires NI-VISA and NI-VISA is not supported in LabVIEW PDA until version 8.2. Aside from this, you can do regural serial communication with PDA 8.0.1 using the Serial Compatibility VI's.
Eli S.
Applications Engineer
(3,177 Views)
thank u for u reply , but i saw  NI_VISA 4.2 is work for Labview PDa 8.0.1 , it is correct or not . Plz Tell ME how cani Implement the Modbus Serial communication using Labview PDA 8.0.1
(3,173 Views)
hi eli  One more  question i.e can i change Modbus  dll to  serial compatablilty VIs wirh out Visa??
(3,171 Views)
Where did you see that VISA 4.2 worked in LV 8.0.1? Visa is only supported in LabVIEW PDA 8.2 and higher and you need VISA to do modbus communication.
Eli S.
(3,150 Views)
