Labview Read INI File Slow
You can also write all elements in the cluster to the ini file yourself.
Simply unbundle the cluster, and write each element to the ini file with
it's own VI. Put it in a nice VI, so you can reuse it.
This is not as fast as writing a binary file, but is probably a lot faster
then automatically storing the cluster to the ini.
Wiebe.
Message 21 of 22
(1,764 Views)
Well, I'm trying the "Read Binary File.vi" and "Write Binary File.vi" that I find in examples, and I'm capable of writing and reading a cluster, and it seems like I get all my data back out again. However, I also get a warning 4 about end of file reached. Does anyone have an explanation on this?  Can I just ignore it?
Message 22 of 22
(1,740 Views)
