Labview: Reset the data in a subVI
This is a test VI to show my problem. I am generating data in a SubVI and passing this to my main VI. This is working but maybe not the best way to do it. I need to be able to reset the arrays in the subVI but am not able to do it. Can anyone point me in the right direction please.
Thanks.
Mark.
(822 Views)
Accepted by topic author vtiu
The most straight forward way is to pass your "Reset Chart" value into the subVI. Then you can use a Case Structure or several Select functions to either use the value in the Shift Registers or an empty array.
(795 Views)
Thanks for the tip. It works fine.
Regards
Mark.
(780 Views)
