Labview State machines Edit Items
VW also needs to use full words instead of text-messaging.  http://forums.ni.com/t5/BreakPoint/A-plea-for-full-words/m-p/751004
Message 11 of 13
(816 Views)
Ohhh Come on 😛
Well to defend myself yesterday was my frist try to help someone....I really want to be active on this forum to learn from it and give it back if I can be helpful.
I wouldn't have even realized if you people weren't pointing at it. Basically I am recent grad (lot of texts :P) and just started working for NI Allince partener, so I go to forums and look for questions when I take a break and may be in hurry to get back to work I have used abbreviations.
I would take all the suggestions and blessings from seniors like Smercurio, Jeff, Ben and Altanbach.
By the way Jeff thanks giving first Kudo of my life, You made my day Smiley HappySmiley HappySmiley HappySmiley HappySmiley Happy
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
Message 12 of 13
(801 Views)
You're welcome for the kudos (with the "s" both singular and plural)  Come on board and help out all you can!
Message 13 of 13
(791 Views)
