Labview System Exec.vi execution problem
Very useful suggestions. ... I suppose to leave the other remote instrument alone for now. But datasocket seems a way for future or now. It will be worth to look into it. You are ahead of me. ... Thanks, for sure.
Message 11 of 13
(1,540 Views)
I didn't understand, even if wait till finished was set to TRUE, it only
should stop the the loop which called the script through system comamnd, not
the other loop which should keep running.
vishi
"judy600" wrote in message
news:5065000000050000008A020100-1042324653000@exchange.ni.com...
> I got my issue solved. ... It is true that the "wait until completion"
> must be wired and set to false. However, the shell script (I use
> Perl) shall not call another script. I let one script involke another
> one. That is the problem!
> Thanks for all the responses! and hope this will help others in future
> ..julia
Message 12 of 13
(1,068 Views)
That is what you think or we all would expect. Base on what I have experienced, LV (Linux version) is not doing that unless you set the wait to False, otherwise it halts all VI executions (regardless they were indepent or not) unil "System Exec.vi" completes its tasks. ...
Message 13 of 13
(1,068 Views)
