Labview TCP/IP
Hello all, I am attempting to stream data over TCP/IP to a raspberry Pi. I have posted about this previously but have made some changes so here is a new post. My goal is to send 1-second block of data to TCP/IP. I am sampling two (2) channels at 100khz with a NI-9215 and getting a timestamp with a NI-9467. On FPGA_Main I am triggering an interrupt every 100K cycles to be able to send the time stamp every theoretical second. In Playaround in the bottom loop I am writing the data over TCP/IP every time a notification arrives, but I believe the loop in which I streaming data over TCP/IP is happening to quickly for the complete 1-second block of data to be sent. The end goal is to send a time-stamp, an associated offset_from_time_reference, and 100k samples for both channels over TCP/IP. The only two VI of concern is the FPGA_Main.VI and the Playaround.VI.
(937 Views)
I am going to change my question. I have changed a little on my main RT VI (the Playaround.VI) and would like to know how can build array or something similar that contains following in order:
1st: the timestamp and offset string in loop two
2nd: 100K samples from both channels (so really 200k)
I am sampling at 100KHz so I would like to build a 1-second chunk of data and then send it over TCP.
Thanks for any help.
(824 Views)
Hi wsimpson0050,
Why not use cluster as you see fit? Flatten cluster to string, send this string over TCP/IP and then decode that string on PI.
@GerdW talked about something similar in this post: https://forums.ni.com/t5/LabVIEW/Read-binary-dump-of-LabVIEW-cluster-from-Python/td-p/4136832
(782 Views)
