Labview Temperature Controller
Hey, I am using Labview to interface with a temperature controller. In order to acquire the data, I am using a while loop. In selecting the reading interval for the device, the number you input is in milliseconds and its supposed to gather 1 value per value of the reading interval. So when I input an interval of 1000, it should acquire one value per second. However, when I acquire 1000 data points, it actually takes ~1075 seconds. Any idea why this may be happening?
(3,946 Views)
Accepted by pvally
I don't see anything in you pic that would control the loop timing but even if there was there is always some overhead in VISA communication and the possibility the OS (unless you're using a real-time OS) will take control and delay your loop.
Basically, f you want perfect timing and deterministic behavior you have to use a dedicated real-time system.  Otherwise you are going to get some timing inconsistencies.
An extra 75 seconds in 1000 seconds seems excessive though.  Maybe try making your hardware collect as fast as it can and add a 1000mS Wait.vi in your loop?
(3,927 Views)
I'm guessing that you're doing a lot of other stuff in series with your acquisition.
(3,927 Views)
Because of overhead on either side of the call.  What it's actually doing is sending a request, then waiting for a reply, then it looks like it sends two other messages as well,then loops again.  So while your sample setting is 1 second long, the time to send and receive to your device is probably about 25 milliseconds, so 1 second plus .025 x 3 = 1.075 per sample, x1000 = 1076 seconds or so.
(3,922 Views)
I can always calculate what the extra time is so I can set the reading interval to slightly lower than 1000 if I want 1 value per second.
(3,905 Views)
I added a wait (1000ms) and changed the reading interval to 100 and it acquired ~1000 data points in ~1000 seconds. Not too sure why this worked but thank you for the help.
(3,894 Views)
It worked because the time it took to collect and read the results was less than 1000mSec.  That means the Wait VI (set at 1000mS) was providing all the loop timing.  This will normally be pretty stable but there are no guarantees without an RT OS.
(3,794 Views)
