Labview Tutorial4 , DAQ Assistent Error
Iam a new User to the Labview System. I use the Labview 8 to learn more about the possibilties of this analytical system. At the moment I need the software to take measurements for a Thesis.
I started with the enclosed Tutorials and was immediatly fascinated by this software. But now at Tutorial 4 I got into trouble, that I couldnt resolve by myself.
It concerns the following...
1. Started by generate the NI-DAQmx at the block diagramm
2. chose analog, voltage like in the Tutorial described
3. picked physical channel "ai01" at the "Dev1 (DAQCard-6036E)"
4. at the next step the DAQ Assistent started to configure the channel (done; like in the Tutorial described)
At this step I try to Test my inputs, but an Error occurs.
"DAQ Assistent Error: Error 200329..." ...while trying to configure the system for a analog capture an error occurs.
I dont know how to solve this Problem... 😞
Used Hardware:
- NI DAQCard 6036E
- NI SC 2345
- some SCC Add-on modules...( one is attached --> SCC-AI01 Isolated analog input)
If you need any further information please ask...
Thanks for your Help.
Regards
Thorsten
(3,038 Views)
Hi Thorsten,
the error you encountered is a hardware configuration error. Typically this error occurs when an external clock is required but missing. In your case, the board might be defective. Therefore, I suggest you check the board's functionality.
Go to the Measurement & Automation Explorer and look for the 6036 device. Try the self-test and the test panel to check the board's functionality. You can also check if the self-calibration works. Please run the DAQ Diagnostics Tool to further analyze the board. If you detect issues with the hardware, please contact NI technical support.
Peter
Peter A.
Field Sales Engineer, NI Germany
(3,017 Views)
