Labview Ubidots
hello, im dandi. i have trouble, i want to get 2 or more value from ubidot to labview, i have done following step from this site
and it's work, but it's just tutorial how to get 1 value from ubidots, and i can not get two or more value from more variable.
so, my question is how to get 2 or 3 value from more variable, i hope you anybody can solve it, sory if my english is not good, please help me, thanks
Message 1 of 11
(8,546 Views)
Hi dandi,
The example explains you need to provide an ID for each variable. Did you try this?
Message 2 of 11
(8,538 Views)
You haven't given us anything to show what you've done in LabVIEW and how it doesn't work.
And what is Ubidots?  The link you gave us talks about how it communicates with LabVIEW, but doesn't say anything about what it actually is.
Message 3 of 11
(8,533 Views)
I quickly read the title and thought I found something like "LabVIEW Proverbs", except about less-than-intelligent LabVIEW programmers.  I am disappoint.
Jim
Message 4 of 11
(8,507 Views)
Accepted by topic author RavensFan
See http://help.ubidots.com/developers/labview-and-ubidots-example for more examples of LabVIEW + Ubidots that include real-time interaction and of how to GET data using the Ubidots' variable API label (not the ID), which should make it easier:
To get more variables just copy and paste the code more times but changing the URL of the variable you wish to read. See here the API docs to get values.
Message 5 of 11
(8,474 Views)
ok i will try this one
Message 6 of 11
(8,469 Views)
i will try it
Message 7 of 11
(8,466 Views)
it's work very well, thanks you very much.
Message 8 of 11
(8,451 Views)
Then you should mark the message that actually gave you the solution as the solution and not your own thank you message.  Go to the options menu to the upper right of your message to unmark it as the solution.
Message 9 of 11
(8,442 Views)
Can you please mark my previous message as the actual solution.
Message 10 of 11
(8,400 Views)
