Labview VI RIGOL Oscilloscope capturing 4 channels - Help
I am having some trouble. I need to create a VI for my program that can capture and display X number of channels from a RIGOL Oscilloscope (DS7024). For example it could be all 4 channels or just channel 2. My issue is whatever I tried I just end up with Channel 4 or multiple channel 4s. Not sure where I am going wrong.
Any hints or ideas would be greatly appreciated. 
(3,098 Views)
First of all thanks for the attached codes and detailed information in there.
I downloaded all of them and tried to make a run "Capture1.VI". As currently, I don't have RIGOL Oscilloscope I run the code with my devices.
Hope that doesn't matter because in output I have a waveform (as in your VI). So from my side, everything worked well, without any errors. I was able to write all acquired data in those 4 csv files.
So for now may I ask you to describe your issue in more detail? What do you mean " just end up with Channel 4 or multiple channel 4s"? Do you get 4 csv files with the same data in that?
Thanks and have a nice day!
(2,966 Views)
