Labview VI using modbus tcp/ip connected to a data acquisition module adam 6017
Hi
I would like to ask why do I have Error 59 on my program. The data acquisition module is connected to my laptop when I used the adam utility software. However, when I tried to use labview, error 59 occurs and no readings are collected. Where did I make a mistake?
Help is greatly appreciated, thank you!
2019-11-12 (2).png is an image of my block diagram.
2019-11-12 (3).png is an image of my front panel.
2019-11-12 (4).PNG is an image showing the data acquisition is connected to by laptop via a ethernet cable.
(2,705 Views)
Accepted by ace2light
Error 59 is that the network is down.
Your one picture with the working programming shows you are communicating with a device at 10.0.0.11.
Your picture with the non-working VI shows an IP address of 169.254.21.119.
Do you think that might the cause of your problem?
(2,694 Views)
Hi
thank you for your help, greatly appreciated! yeah, it is because of my ip address.
(2,674 Views)
