Labview & Optotrak
I'm using Optotrak sensors & I'm wondering how I can stream / read values real time to labview
(4,020 Views)
What is a "Optotrak sensor?"
(4,015 Views)
Sorry I meant optotrak camera with a marker to read the positon
(3,995 Views)
Assuming this is the system in question, it says near the bottom of that page that it supports "Real-time Data Streaming to 3rd Party Software".  That's what you'll want to use, but I'm not seeing anything more on that page indicating how exactly it's used.  There's a support site walled off to anyone who isn't a customer.  I suggest you contact them for details.
Most likely they have some sort of interface using a DLL or an ActiveX object that you can use with LabVIEW, based on other 3rd party software with similar functionality that I've used.  Do you already have the hardware/software in question?
(3,984 Views)
I have contacted them but so far no reply. That's why I was hoping someone else knowes
(3,977 Views)
I did help a customer here in the Netherlands with a project but that is about 15 years ago. The programming was done in LabWindows/CVI though. The camera system in question had a DLL interface that could be called. I don't have any of that software anymore but a quick search showed up this document describing an API.
Here they talk about Optotrak Certus which I assume is a more modern system and it mentions:
  • Integrates with LabViewâ„¢ using OAPI
Rolf Kalbermatter  My Blog
(3,965 Views)
