Labview and VT100.
I have an instrument that communicates over serial using the VT100 protocol.
I understand that this protocol is an extension of the regular ASCII
character set, implementing such things as arrow keys and function keys.
Would I be better off looking for a DLL that implemented the keyboard
mapping - or writing a Labview function that did the same? I'm most worried
about formatting the strings that return from the instrument. Speed is not
that much of a priority.
John
(3,959 Views)
I'm facing the same problem right now. I have the same issue with formatting the return strings. I have to know which menu is active (a specific item is highlighted) and then retrieving data from a field. The method I'm pursuing right now is to use a terminal emulation program with an ActiveX interface. The makers of Hyperterminal make a product called Hyperaccess that has an ActiveX manual about an inch and a half thick that I am slowly going through. I already have a C++ program that does most of what I want so I'm undecided whether to port everything over to LabVIEW ActiveX calls or to modify the C++ program. If anyone has any better ideas, I'd be glad to hear them as well.
(3,959 Views)
I believe a "ctrl-w" used to be a refresh the screen command.
If that is supported by the equipment, you can use that function to get the entire screen updated. I am not sure if that helps.
Would digging up an old VT-100 manual be of any use? I just may have the pocket guide on my shelf at home. Let me know if you want me to look.
Ben
(3,959 Views)
I've got most of the VT-100 protocols but it's pretty tedious to parse everything out and I'm trying to avoid that. The thing I'm interfacing to sends data out in pieces. For example, I get the row/column and then the string and then another row/column and string but it might not be the adjacent field and then I have to determine whether the field is highlighted to know whether that's active so that's another set of control codes to format. Then, if I want to display all the text in a LabVIEW string control, it gets really messy lining things up in different columns and showing highlighted and non-highlighted text. All these things are do-able but it all boils down to reinventing the wheel.
(3,959 Views)
OK,
I was just trying to help.
Ben
(3,959 Views)
I really do appreciate the offer Ben. If I came off a little cranky, I apologize. I have some good memories of programming on PDP-11s but the VT100 stuff wasn't one of them and this new project where I have to interface to a product with an obsolete UI has put me me in a bit of a foul mood.
(3,959 Views)
No problem Dennis!
I looked last night and could not find it after all.
I did find my pocket reference card for the PDP-11 instruction set.
Do you remeber "012737"?
(Move the data that follows to the address that follows).
Now those were the days...
Ben
(3,959 Views)
