how do I uninstall lvruntime engine 7
I installed the LVRuntimeEngine 7.0.msi on my computer. I want to uninstall it but I don't see it in my Add/Remove Programs menu. How can I uninstall it?
(3,121 Views)
Hello.
You should be able to uninstall the LabVIEW run-time engine by going into National Instruments software in the Add/Remove Programs list in Windows.
Note that I don't think you can (or should) remove it if you have the same version LabVIEW installed. If, for example, you have LabVIEW 7.1 installed, along with its runtime engine, it is OK to uninstall the LabVIEW 7.0 runtime engine, but NOT the 7.1 one.
(3,121 Views)
Hi there,
You can use msiblast to uninstall it too.
Regards.
Joris Vanderschrick
Team Leader Application Engineering
NI Belgium
(3,121 Views)
