Labview and phidget bridge 1046 module
Hi
Did you try change the gain value?
best
cpalka
Message 11 of 12
(698 Views)
Thanks a lot Cpalka for your response.
I really appreciate your time and effort.
Gain rate 128 gives the minimum error but it is still a lot if I am interested to measure few gm sensitive variation in the load. Currently I am getting a variation of almost 20-25 gm from actual value. And this variation does not have a constant trend each time.
Do you think it might be because of static electricity produced by human body? Or it should not be a reason for large variations?
Please guide me if you think of any reason and solution for this.
Tehreem
Message 12 of 12
(689 Views)
