Labview combine two 1D array into 2D array and merging 2D array
Hi!!! how do I combine two 1D array into 2D array.They have the same amount of row and column. So I am trying to get 2 column of data side by side.
I also need help in merging multiple 2D array, I have multiple 2D array with 2 column. However, one of the column's data is exactly the same as other 2D array. So how do I merge all the data together?
Message 1 of 15
(17,317 Views)
You can build the 1D array so that you can get 2D array. For combining 2 2D array you have to build the array and enable Concatenate inputs.
Message 2 of 15
(17,316 Views)
I have get the 1D array but how to combine to get 2D array?
Message 3 of 15
(17,312 Views)
Just use the build array function.
Message 4 of 15
(17,305 Views)
I tried but the value is incorrect.
Message 5 of 15
(17,300 Views)
Please post the code that you have tried.
Message 6 of 15
(17,298 Views)
I think this could help you :
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 7 of 15
(17,296 Views)
I have to give Kudos to TiTou for showing off video.
Nextal, can you give some sample data so we can see what you are trying to do?
Message 8 of 15
(17,285 Views)
Hi all. I am unable to show you my code now. I don't have the code with me now as it is at my workspace. Okay what I am trying to do now is is that I have a number from 0 to 255. every 5 step it will get a data from my detector. What I am doing now is to store the value in array. I had successfully build my 1D array for my data and 1D array for the number. I am not clear in expressing here is a example.
Number 1D array                  Data 1D array
0                                           0.9236
5                                           1.2653
10                                         1.1940
15                                         1.2691
20                                         0.9987
25                                         1.4567
30                                         1.9746
35                                         1.3445
40                                         1.9953
255                                       1.4372
How I get all this value into a 1D array is to use a while loop with shift register and store it.
What I am trying to achieve now is to get a 2D array with data side by side. I am using the build array vi:
Combine 2D array
0     0.9236
5     1.2653
10   1.1940
15   1.2691
20   0.9987
25   1.4567
30   1.9746
35   1.3445
40   1.9953
255  1.4372
I used the build array and the number from 0 to 255 show correctly. However, for my data I only get the first data 0.9236 for every number.
Any ideal why this happen??
What I am getting now is:
Combine 2D array
0     0.9236
5     0.9236
10   0.9236
15   0.9236
20   0.9236
25   0.9236
30   0.9236
35   0.9236
40   0.9236
255  0.9236
Message 9 of 15
(17,264 Views)
By the way this is how I create my 2D array.
Message 10 of 15
(17,257 Views)
