Labview combine two 1D array into 2D array and merging 2D array
why aren't you just doing this:
Message 11 of 15
(4,734 Views)
Hi guys thank for all your help!!! I had successfully created my 2D array but now I have a problem how do I combine the 2D array with another column of data(maximum) which I acquire from some calculations?
here is what I am trying to get:
0     0.9236    0.2132
5     1.2653    0.1565
10   1.1940    0.9875
15   1.2691    0.9874
20   0.9987    0.6663
25   1.4567    0.2945
30   1.9746    0.1236
35   1.3445    0.2568
40   1.9953    0.1459
255  1.4372   0.1278
I need them to be side by side. Because I need to get the highest maximum value and return the correspond row then use the value inside the row for other calculation.
currently I have a 2D array:
0     0.9236
5     1.2653
10   1.1940
15   1.2691
20   0.9987
25   1.4567
30   1.9746
35   1.3445
40   1.9953
255  1.4372
and a 1D array:
0.2132
0.1565
0.9875
0.9874
0.6663
0.2945
0.1236
0.2568
0.1459
0.1278
How can I do this?
Message 12 of 15
(4,715 Views)
The same way just build the 2D and 1D array.
Message 13 of 15
(4,709 Views)
So I combine and transpose array?
Message 14 of 15
(4,703 Views)
Yes if required you need to transpose the array.
Message 15 of 15
(4,701 Views)
