Labview connect with Microsoft SQL 2019
How to solve that Labview takes time While make connection with Microsoft SQL server 2019 ?
Message 1 of 8
(3,411 Views)
  • How to solve that Labview takes time While make connection with Microsoft SQL server 2019 ?
Message 2 of 8
(3,408 Views)
Not exactly sure what your problem is, but to connect to SQL database with Labview you need Database Connectivity Toolkit.
Message 3 of 8
(3,324 Views)
and the Open Connection VI of that toolkit has a default time-out setting of 15 seconds.
If that is not enough you probably never get connected ðŸ¤£
Kees
Message 4 of 8
(3,302 Views)
I am using Labview 2019 version  to make connection with Microsoft SQL2019.i have make connection through ODBC.Labview 2019 takes time to make connection with Microsoft SQL 2019.how can i solve that  delay issue ?
Message 5 of 8
(3,238 Views)
How long is the delay?
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 6 of 8
(3,225 Views)
it takes 7-10 secs
Message 7 of 8
(3,184 Views)
@duraik756 wrote:
it takes 7-10 secs
If I were you, the next thing I would do is look at Wireshark to see who is taking that much time, but that is me. Are you using the database connectivity kit or some other ODBC library?
Message 8 of 8
(3,167 Views)
