Hi all,
Windows XP
Labview 6i
NI GPIB card in PXI chassis over MXI-3 PCI bridge.
I am trying to write a VI to control a TTi1705 Multimeter via GPIB. I
can access the instrument, and have a case structure with a Menu Ring
to set either VAC or VDC. If i put this in a while loop, it runs fine;
if the setting is changed, then it programs the meter accordingly.
If I now put in the same while loop, a two stage sequence (GPIB Write
"READ?" and a GPIB Read) to get the current voltage being measured,
this also works as required. Until.... I change the AC/DC ring. When I
do this, it still sets the meter accordingly, but now the wrtie/read
sequence stops, and eventually reports "GPIB Read returned error code:
EDVR: Error connecti
ng to driver or device".
Either selecting Continue or Abort, then re-running the VI allows the
write/read sequence to operate again OK, until the AC/DC is changed
again.
Does anyone know why this is happening or how I could fix it?
Any help appriciated!
Joe.
