Labview crashed on Mac OS X Sierra: 'nextEventMatchingMask should only be called from the Main Thread!'
Thank you for taking time looking into this issue.
My testing environment has mac only, so I have to stay with OS X. I need to get the company approval on Budget to switch to Windows.
Message 11 of 20
(3,891 Views)
Sorry it has taken me awhile to get back. I did not have my Mac with me. What software are you using for your coding?
Madison T
Message 12 of 20
(3,870 Views)
Are you asking about the IDE? If so, I am using the Xcode command line tools.
Message 13 of 20
(3,845 Views)
Dear all, I am expariencing the same problems. You can use this to reproduce the error. Hope this can help. My compute is a MacBook Pro 15" just bought with Sierra and Nidaqmx base 15.
I used the examples provided by NI in the ai subfolder with an USB 6216 which is correctly recognized by lsdaq
NI USB-6216: "Dev1"    (USB0::0x3923::0x733B::0166EF64::RAW)
The example compiles without problems
gcc -O2 -arch x86_64 -F/Library/Frameworks -Wno-format  -framework nidaqmxbase -framework nidaqmxbaselv acquireNScan.c -o nScan
but when I run it I get the error
Creating task
2017-02-23 11:32:25.765 oneScan[18003:2921915] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'nextEventMatchingMask should only be called from the Main Thread!'
*** First throw call stack:
0 CoreFoundation 0x00007fff9ba56e7b __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffb0640cad objc_exception_throw + 48
2 AppKit 0x00007fff99c793fd -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 4471
3 LabVIEW 15.0 Runtime 0x0000000113a14b91 WEventAvail + 833
4 LabVIEW 15.0 Runtime 0x00000001137aea7e Exec + 1246
5 LabVIEW 15.0 Runtime 0x00000001137a3f8a _Z16DoBackgroundExeci + 202
6 LabVIEW 15.0 Runtime 0x000000011393be6a _ZN12BGAppTask_MG11HandleTasksEi + 138
7 LabVIEW 15.0 Runtime 0x000000011392cfe3 _ZN15BGAppTask_MacUI21CheckAndHandleBGEventEv + 51
8 LabVIEW 15.0 Runtime 0x000000011392fc6d _Z33BGAppTasksRunLoopObserverCallbackP19__CFRunLoopObservermPv + 301
9 CoreFoundation 0x00007fff9b9ec397 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
10 CoreFoundation 0x00007fff9b9ec307 __CFRunLoopDoObservers + 391
11 CoreFoundation 0x00007fff9b9ccf5a __CFRunLoopRun + 906
12 CoreFoundation 0x00007fff9b9cc974 CFRunLoopRunSpecific + 420
13 LabVIEW 15.0 Runtime 0x000000011392b387 _ZN19MainLoop_MacCocoaUI3RunEv + 279
14 LabVIEW 15.0 Runtime 0x0000000112c96a46 _Z6MGMainiPKPKc + 294
15 LabVIEW 15.0 Runtime 0x0000000112c9750d _Z11SysUIThreadPv + 13
16 LabVIEW 15.0 Runtime 0x0000000113a8b03e _Z15ThreadCoverProcPv + 94
17 libsystem_pthread.dylib 0x00007fffb113baab _pthread_body + 180
18 libsystem_pthread.dylib 0x00007fffb113b9f7 _pthread_body + 0
19 libsystem_pthread.dylib 0x00007fffb113b1fd thread_start + 13
libc++abi.dylib: terminating with uncaught exception of type NSException
Abort trap: 6
Message 14 of 20
(3,831 Views)
Do you have any luck resolving this issue. After upgrading to sierra, the previous compiled examples are working, however if I compile new ones they crash with the same error:
2017-10-28 23:48:06.222 acquireNScans[1234:37253] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'nextEventMatchingMask should only be called from the Main Thread!'
0   CoreFoundation                      0x00007fff8d63f57b __exceptionPreprocess + 171
1   libobjc.A.dylib                     0x00007fffa28a01da objc_exception_throw + 48
2   AppKit                              0x00007fff8b82ae82 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 4480
3   LabVIEW 15.0 Runtime                0x000000010ebc1b91 WEventAvail + 833
4   LabVIEW 15.0 Runtime                0x000000010e95ba7e Exec + 1246
5   LabVIEW 15.0 Runtime                0x000000010e950f8a _Z16DoBackgroundExeci + 202
6   LabVIEW 15.0 Runtime                0x000000010eae8e6a _ZN12BGAppTask_MG11HandleTasksEi + 138
7   LabVIEW 15.0 Runtime                0x000000010ead9fe3 _ZN15BGAppTask_MacUI21CheckAndHandleBGEventEv + 51
8   LabVIEW 15.0 Runtime                0x000000010eadcc6d _Z33BGAppTasksRunLoopObserverCallbackP19__CFRunLoopObservermPv + 301
9   CoreFoundation                      0x00007fff8d5d5de7 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
10  CoreFoundation                      0x00007fff8d5d5d57 __CFRunLoopDoObservers + 391
11  CoreFoundation                      0x00007fff8d5b6b2a __CFRunLoopRun + 906
12  CoreFoundation                      0x00007fff8d5b6544 CFRunLoopRunSpecific + 420
13  LabVIEW 15.0 Runtime                0x000000010ead8387 _ZN19MainLoop_MacCocoaUI3RunEv + 279
14  LabVIEW 15.0 Runtime                0x000000010de43a46 _Z6MGMainiPKPKc + 294
15  LabVIEW 15.0 Runtime                0x000000010de4450d _Z11SysUIThreadPv + 13
16  LabVIEW 15.0 Runtime                0x000000010ec3803e _Z15ThreadCoverProcPv + 94
17  libsystem_pthread.dylib             0x00007fffa339a93b _pthread_body + 180
18  libsystem_pthread.dylib             0x00007fffa339a887 _pthread_body + 0
19  libsystem_pthread.dylib             0x00007fffa339a08d thread_start + 13
Abort trap: 6
Message 15 of 20
(3,423 Views)
Accepted by topic author qizheng_square
No, no luck at all. so I stopped using NI's product. I suggest to use MCC DAQ, which uses open-source libusb and libhid, and works way better.
Message 16 of 20
(3,414 Views)
Hey I am facing the same error on my macos high sierra 10.13.3
Any solutions?
And what is the alternative API for macos?
mcd daq does not seem to have macos support
Message 17 of 20
(3,297 Views)
If you are using NI-DAQmx Base 15, Mac OS X 10.13.13 is not officially supported (see the description tab): http://www.ni.com/download/ni-daqmx-base-15.0/5648/en/.
What version of LabVIEW are you using? LabVIEW 2017 SP1 does support Mac OS 10.13.
Lastly, even though you are encountering a similar issue, you may gain more visibility by creating a new forum post.
Brian.D
NI Product Owner
VeriStand
Message 18 of 20
(3,278 Views)
I have the same problem with High Sierra. This simple program produces the same error message.
#include <stdio.h>
#include <NIDAQmxBase.h>
  int main(void) {
      TaskHandle task;
      int ret_code;
      ret_code = DAQmxBaseCreateTask("", &task);
      printf("ret_code = %d\n", ret_code);
      return 0;
Result:
% ./Essai
2019-02-18 13:08:34.858 Essai[3223:51476] *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'nextEventMatchingMask should only be called from the Main Thread!'
	0   CoreFoundation                      0x00007fff45c9e23b __exceptionPreprocess + 171
	1   libobjc.A.dylib                     0x00007fff6cf2fc76 objc_exception_throw + 48
	2   AppKit                              0x00007fff43949297 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 4167
	3   LabVIEW 15.0 Runtime                0x00000001117c1b91 WEventAvail + 833
	4   LabVIEW 15.0 Runtime                0x000000011155ba7e Exec + 1246
	5   LabVIEW 15.0 Runtime                0x0000000111550f8a _Z16DoBackgroundExeci + 202
	6   LabVIEW 15.0 Runtime                0x00000001116e8e6a _ZN12BGAppTask_MG11HandleTasksEi + 138
	7   LabVIEW 15.0 Runtime                0x00000001116d9fe3 _ZN15BGAppTask_MacUI21CheckAndHandleBGEventEv + 51
	8   LabVIEW 15.0 Runtime                0x00000001116dcc6d _Z33BGAppTasksRunLoopObserverCallbackP19__CFRunLoopObservermPv + 301
	9   CoreFoundation                      0x00007fff45c362f7 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
	10  CoreFoundation                      0x00007fff45c3621f __CFRunLoopDoObservers + 527
	11  CoreFoundation                      0x00007fff45c187b3 __CFRunLoopRun + 1267
	12  CoreFoundation                      0x00007fff45c18033 CFRunLoopRunSpecific + 483
	13  LabVIEW 15.0 Runtime                0x00000001116d8387 _ZN19MainLoop_MacCocoaUI3RunEv + 279
	14  LabVIEW 15.0 Runtime                0x0000000110a43a46 _Z6MGMainiPKPKc + 294
	15  LabVIEW 15.0 Runtime                0x0000000110a4450d _Z11SysUIThreadPv + 13
	16  LabVIEW 15.0 Runtime                0x000000011183803e _Z15ThreadCoverProcPv + 94
	17  libsystem_pthread.dylib             0x00007fff6de61661 _pthread_body + 340
	18  libsystem_pthread.dylib             0x00007fff6de6150d _pthread_body + 0
	19  libsystem_pthread.dylib             0x00007fff6de60bf9 thread_start + 13
Abort trap: 6
Message 19 of 20
(2,771 Views)
I have found some additional information. If the same code is compiled with -arch i386, then I get a warning but it does not crash and appears to work.
Here is the warning:
2019-02-18 14:15:18.868 Essai32[4872:81953] pid(4872)/euid(501) is calling TIS/TSM in non-main thread environment, ERROR : This is NOT allowed. Please call TIS/TSM in main thread!!!
Any idea why the discrepency between 32-bits and 64-bits libraries ?
Message 20 of 20
(2,765 Views)
