Labview crashes when using NX client
I can use Labview from the Linux console, but when using Nomachine NX to connect, I get the following error & crash when trying to launch Labview:
LabVIEW caught fatal signal
12.0 - Received SEGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x0x72657375
No extra hardware is attached.
Platform: RedHat Linux 5.9 64bit
Product: Labview base package
(4,075 Views)
In order to help you better with your issue, I was wondering if you can give more information about when exactly you receive the error message. Do you receive the error message when you open LabVIEW or when you are running a VI or an executable?
(4,052 Views)
The error appears on start-up of Labview. I only have to run labview at the command line and wait for the crash and error message.
(4,047 Views)
bump
(4,021 Views)
Related with your issue,I have found the following KB that talks about it:
http://digital.ni.com/public.nsf/allkb/A2D53C8E0D88380B86256EBD005B31D2
(4,004 Views)
I'm having a graphics-related issue. Your suggestion was not applicable. Labview works on the local console, but fails when trying to use it remotely via the NoMachine NX client. Can you tell me how to disable hardware-rendering for Labview so that I can verify this?
(3,987 Views)
