reset timer using an event structure
I wrote a simple code to count second and the timer can be reset if I press the 'reset' buttom.
It works; however, there are two problems,
1. When I start the program, the timer takes 1 second to start
2. When I press the reset buttom, the timer also takes 1 second to respond
I believe it is the 1000ms connected to the left corner of the event structure. Is there a better way to overcome this issue? (the timer starts and resets immediately
when I start the program and hit the 'reset' buttom)
thank you!!
(3,982 Views)
Accepted by topic author ivy037
Dear ivy037
you could bring the Time Elapsed outside of the event structure as done in the attached code.  Let me know if this is satisfactory.
Robert Ward
Applications Engineer, NI
(3,973 Views)
One small movement, One big change!!
(3,971 Views)
thank you!!
Spoiler
(3,964 Views)
