Labview dc voltage source
I want to put variable dc voltage supply with certain range of voltage and current values. So can someone please help me out in this ? It’s very important for me.
Thank you.
Message 1 of 19
(7,071 Views)
You probably won't get much help.  You haven't provided any real information.
What brand/model of DC voltage supply?
How do you plan to communicate with it?
Have you read the manual?
Searched the manufacturers website or googled to see if any LabVIEW drivers have already been written for it?
Message 2 of 19
(7,032 Views)
Have you even picked out a supply?  What voltage and current ranges do you need?  How quickly do you need to update the output?  The information you can give us, the better advice we can give you.  It is extremely rare anybody asks for less information.
Message 3 of 19
(6,991 Views)
Hey thanks for replying,
I want to model one test circuit in that I need Vdd supply voltage as user settable from 50 to 100 V. but I also want this voltage supply source also has current limit function as well as like voltage range.
Thank you.
Message 4 of 19
(6,971 Views)
hey thanks for replying
here I am sending you a whole program which I want to execute in labview. please find attached photo below and try to give me help as much you can.
Thank you.1122
Message 5 of 19
(6,965 Views)
So this isn't some manufacturer's device you are trying to control, but some electronic circuit you are building?  How do you expect LabVIEW to control it?
Message 6 of 19
(6,959 Views)
No, I am trying to control hewelett Packard 6030A system power supply device with this specifications. 0-200 V / 0-17 A , 1000 W.
Message 7 of 19
(6,948 Views)
That's good.
So what does the schematic you attached mean to us?
What does the manual for the HP tell you about how to control it?
Message 8 of 19
(6,935 Views)
Then start by downloading the LabVIEW drivers for that power supply: Agilent 6XXX Series Power Supply LabVIEW Driver
Message 9 of 19
(6,934 Views)
ok, and I also want to control HP 33120A 15 MHz function generator and
TENMA 72-8335A DC power supply device.
Message 10 of 19
(6,921 Views)
