Labview does not run with SCPI commands
I tried all options with : and ; but nothing worked.
I also tested it via RS232 but ist didnt work either.
Visa Write (in Labview) works, as well as the other visa commands in labview.
And now the good news: Someone told to me that i have to install the "UPV-K4 Remote Control" on the Analyzer. I got a key for that but when i want to install it, an error right next to the code occurs: "deactivated (by time monitor)". I have set my time i have updated the clock and restarted the Analyer, however it still did not work.
Message 21 of 24
(1,588 Views)
 Here is the picture:
Message 22 of 24
(1,587 Views)
If VISA works then use it, there seems to be some issue with their labview implementation.
Message 23 of 24
(1,576 Views)
I managed to install the K4-Option.
Now everything works.
Thank you all for your help and patience!!!
Message 24 of 24
(1,532 Views)
