Labview failed to call python,code"1671"
Hi, I run the demo of labview2018, "PythonNode_AddTwoDoubles",
The example returns an error code"1671".QQ图片20181023151217.pngQQ图片20181023151217.png
labview2018, 64bit
python 3.6.5, 64bit
computer win10
Can anyone help me with this problem? Thanks!
Message 1 of 13
(13,887 Views)
Error 1671 occurred due to the location where you store the python code.
LabVIEW 2018 does not support network storage, try to move your python code to a local storage to solve this problem.
Error code link
Message 2 of 13
(13,856 Views)
It dosen't solve my problem.
My python code was on local storage originally.
And I run the demo of LV2018, the same error code 1671
Message 3 of 13
(13,853 Views)
I saw your another post in Chinese sub-forum stating that you are using Python in Anaconda environment.
Anaconda Python may have compatibility issue when it comes to using Python node in LabVIEW. Have you try to use traditional Python instead?
The official supported version of Python that is supported by Labview is Python 2.7 and Python 3.6
Message 4 of 13
(13,828 Views)
Hi, JaredLoy
Thank you for replying to me,
I tried everything to connect python,
Anaconda, traditional Python, the version of software and so on,
All failed. code "1671". That may not work.
I gave up using the Labview to call Python.
Message 5 of 13
(13,794 Views)
Change to local storage works for me! Thanks.
Message 6 of 13
(13,725 Views)
Are the any updates to this problem?
I encounter the same problem:
- LV 2018 (32bit) on Win10
- Python 3.6.2 (32bit)
everything is local on C:\
---> Open Python Session in TestPyhonNode.vi<APPEND>
Python returned the following error: Error creating host process (Code 1671)
This is really anoying as the python features was the only reason for me to consider an update to LV2018.
Message 7 of 13
(13,703 Views)
I saw this Error Code when I open *.py saved in Visual Studio.
Try to open *.py in Notepad and save as ANSI
Message 8 of 13
(13,599 Views)
This does not help. It is already the "Open Python Session"-VI what is crashing.
Win10+Python 3.6 (32bit) + LV2018 (32bit), the path is set
Message 9 of 13
(13,579 Views)
bumping this up.  Im trying to use python 2.7.12. Both Python and LabView 2018 are 32 bit.  I get the same error as the above poster (error 1671 at the output of the Open Python Session.vi).  I do have the c:\python27 dir in the sys path. The python27.dll is located there.  I have tried '2.7' and '2.7.12' as the version and both yield the same error.  The python code works great.   Everything is local/no network paths or anything.
Lets get this figured out. Seems like its a common issue.
thanks
Message 10 of 13
(13,501 Views)
