Labview for Tektronic DSA71254B, how to read mean-delay value
Dear all,
I'm using a Labview Project-Style Drive (tektronix_7000_series) for my Tektronic DSA71254B.
I'd like to read waveform-measurement mean delay between signals of Channel 1&2 and I use Read Waveform Measurement (Time).vi but it just shows the instant delay, not the mean delay.
Could you please help me how to read mean-delay value?
Thank you.
(2,605 Views)
Accepted by Mike Kan
Dear Mike Kan,
My name is Yusuke Minami, Applications Engineer, National Instruments Japan.
Let me introduce the following example VI that determines delay between two signals.
Determine Sample Delay Using Cross Correlation
https://decibel.ni.com/content/docs/DOC-12657
Hope this helps.
Yusuke Minami
Applications Engineer, NI Japan
日本ナショナルインスツルメンツ株式会社 技術部 巳波裕介
Yusuke Minami, Applications Engineering, National Instruments Japan
技術サポートウェブページ: http://www.ni.com/support/ja
お問い合わせフリーダイヤル: 0120-527196
(2,572 Views)
thanks for your kind reply and the cross correlation.
This solution is new to me but helpful.
(2,562 Views)
