Labview function like C# Properties.Settings.Default.Save();
Again - you can't do anything until your code runs. Everything should be handled by your code. You cannot change the default values for front panel controls; you can only load new values programmatically.
Message 11 of 12
(497 Views)
Understood.  Thanks nathand.
Message 12 of 12
(483 Views)
