Labview icons - smaller - nicer
Hello
Sometimes I need to create small icons like standard increment or
division. They have special shape and size which makes diagram
friendly and easy to follow. When I create my own vi it has
always rectangular icon. I can edit the picture on the icon, but
I can not edit the shape of the icon. Is there any way to do it?
thanks in advance.
regards
PP
Message 1 of 13
(4,425 Views)
Hello, Pawel
You can draw in icon editor small icon as you want.
If you don't create terminals so you will see exactly small icon with your shape in diagram. But if you connect terminals, icon must cover also places of connections to terminals. So when you draw your custom icon, select "Show terminals" option of Icon Editor and draw correspondly to your teminals.
Message 2 of 13
(4,425 Views)
Here i attached example.
Message 3 of 13
(4,425 Views)
If you copy the 256 color icon to 16 and B & W, all excluded white areas
become invisable. However, when you click on such a white area, the VI is
still selected. This cannot be prevented.
An article about this was published in an issue of LTR, maybe it's published
online...
Be carefull; using this technique can confuse other people (esp. beginners)
when they use the code. (VI's may not be recognised as VI's, clicking wires
doesn't seem to work, clicking a vi selects another transparent VI, etc.)
Wiebe.
"Pawel Pocwiardowski" wrote in message
news:3D3F9F1F.9B8307AB@poczta.onet.pl...
> Hello
> thanks in advance.
> regards
> PP
Message 4 of 13
(4,426 Views)
Hi Wiebe
Yes, that is correct, I have noticed this. Could you pass me the
vol. and number of LTR I am sure I have it.
thanks
regards
PP
"Wiebe@AIR" wrote:
> Hi,
> online...
> Regards,
> Wiebe.
artapaw@poczta.onet.pl> wrote in message
> > Hello
> > thanks in advance.
> > regards
> > PP
Message 5 of 13
(4,199 Views)
This is a very nice example, thank you, but I have noticed that
it behaves as it has the outline corresponding to the big icon. I
means when I have mouse over the square (the basic one) it
indicates that this is this object. Unlike in original Labview
vi, like increment or multiplier, the object is selected after
direct pointing it with the mouse on the draw area not on the
outline.
But I think this technique is satisfactory for me anyway. So
thank you all, a lot.
best regards
PP
> fish.zip Type: Zip Compressed Data (application/x-zip-compressed)
> Encoding
: base64
> Description: example of vi with small icon
Message 6 of 13
(4,426 Views)
Hi, Pawel
increment or multiplier are not VI's. This is built in LabVIEW code, exactly as images of different LabVIEW structures or wires.
Message 7 of 13
(4,426 Views)
It's Volume 8, Number 4, page 16
Wiebe.
news:3D3FC626.61BB3A17@poczta.onet.pl...
> Hi Wiebe
> thanks
> regards
> PP
> "Wiebe@AIR" wrote:
> > Hi,
is
published
> > online...
beginners)
> > whe
wires
etc.)
> > Regards,
> > Wiebe.
> > > Hello
> > > thanks in advance.
> > > regards
> > > PP
Message 8 of 13
(4,199 Views)
How do you know they are not! Any VI can be turned into something like
"increment" function, which can be opened. One NI engineer said that,
but he didn't say (or didn't want to say) how.
> Hi, Pawel
Message 9 of 13
(4,426 Views)
Thank you, I see I have it.
best regards
PP
> Regards,
> Wiebe.
> > Hi Wiebe
> > thanks
> > regards
> > PP
> > "Wiebe@AIR" wrote:
> > > Hi,
> is
LTR, maybe it's
> published
> > > online...
> beginners)
> wires
> etc.)
> > > Regards,
> > > Wiebe.
> > > > Hello
> > > > thanks in advance.
> > > > regards
> > > > PP
Message 10 of 13
(4,199 Views)
