Labview installation
Hi All.
I need to install labview on my computer which has the following features
What version of labview do you suggest is better?
I have got more or less 8 GB of space free in my hard disk .
Thanks in advance
(3,080 Views)
Accepted by nicop92
@nicop92 wrote:
Hi All.
Thanks in advance
Is it true that your laptop only has 1GB of memory???  I'm surprised an operating system can even run in that small space, much less OS + LabVIEW.  Also, while LabVIEW might install into 8GB of disk space, you won't have much room for pagefile.sys - which would need to be huge to be able to run Windows in 1GB of space.
I really can't recommend you install any version of LabVIEW, but if you must try, here's a link to LabVIEW/Windows compatibility matrix:
https://www.ni.com/en-us/support/documentation/compatibility/17/labview-and-microsoft-windows-compat....
Bill
CLD
(Mid-Level minion.)
(3,062 Views)
Hi. Thanks for answering my question.
As for RAM, unfortunately it is true. Never had problems with running the OS (just consider that this machine is something between a laptop https://www.amazon.co.uk/Mediacom-WinPad-10-1-X100-Black/dp/B00OIZQVFG ). I'll have to buy a new PC...
(3,041 Views)
