Showing results forĀ
Search instead forĀ
Did you mean:Ā
Labview interface for Arduino Failed
Hi
I bought Arduino Mega 2560. I want to interface labview with arduino. I have installed Arduino IDE 1.7.3. I am using Windows 7 64bit version and Labview 2012. When I tried to compile LIFA_Base File with Arduino IDE there is the following error:
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
Error compiling.
I tried to delete the folder   C:\Program Files (x86)\Arduino\libraries\RobotIRremote but without success.
Please help me to resolve the problem.
Regards
Message 1 of 8
(5,612 Views)
Accepted by tiho
Lifa is obsolete and no longer supported. Why aren't you using Linx?
https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
Message 2 of 8
(5,605 Views)
Accepted by tiho
Hi
Thank you for your answer. I resolved my problem. I closed Arduino IDE, deleted the folder C:\Program Files (x86)\Arduino\libraries\RobotIRemote and started Arduino IDE again. Everything is OK now.
Thank you for your suggestion to use Linx
Regards
Message 3 of 8
(5,571 Views)
Hello Dennis_Knutson
I new in LabVIEW Interface for Arduino. What do you suggest me for beginner  ?
Actually ı saw your comment.What are diffrences Linx between LİFA ?
Thank you for your attention.
Message 4 of 8
(5,423 Views)
What I know of Linx is that it has support for more hardware and additional features/functions.
Message 5 of 8
(5,416 Views)
I suggest you to buy Arduino Mega 2560 or Arduino Uno. It is very easy to start working. You have to install Arduino IDE and to delete the file that I wrote in my conversation above. I don't know the difference between Lifa and Linx. May be Linx is better but I work with Lifa.
Regards
Message 6 of 8
(5,387 Views)
LINX is better because LIFA is no longer actively supported by National Instruments. I suggest you start working with LINX. May some problem can be happen for later.
Message 7 of 8
(5,374 Views)
Hi tiho,
LIFA_BASE will compile properly only in arduino IDE version 1.0.5 and lower.
Message 8 of 8
(5,196 Views)
