Labview interface for sending data CAN interface
Is it possible to use linx to make an interface on LabVIEW to send data from one Arduino Uno board to another Arduino board? I want to use one board as a master, which communicates with the PC, and another that receives data. The master board will have the linx firmware and the second board a receive program built in the Arduino IDE. I want to use this library. I use these two modules as transceivers with MCP2515 and TJA1050.
Can you give me some links on how this can be done? Some tutorials/hints... I really don't know if I can use the SPI vis from linx to get the job done, or if I need to do some particular vis or change the firmware.I can be done using lifa?
(3,132 Views)
Hi BogdanM,
I'd check out www.ni.com/arduino for this issue instead of the standard LabVIEW forums, as the users who are over there are much more familiar with interfacing NI products with Arduino boards.
Tyler O.
(3,078 Views)
