Removing duplicate rows of numeric 2D Arrays
I'm trying to work out how to remove duplicate rows in an array. For Example:
Before:
1 0 1
0 0 1
1 0 1
1 1 1
After:
1 0 1
0 0 1
1 1 1
Any ideas would be great!
(3,817 Views)
If you want a fast answer, you will have to wait until Altenbach responds, but in the meantime, this should do 🙂
(3,797 Views)
Accepted by topic author LiamMcNulty
Variant attributes are great for this type of work!
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,762 Views)
Just Another approach.
Hope Yaemada has given simplest one!
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,755 Views)
