Labview interface with micro contoller
Accepted by jaga_ji
U can use Serial communication protocol.
No need of DAQ card
Message 11 of 17
(2,167 Views)
Instead of c/c++,can i user labview program for embedded appilcation?
if So How?
J@G@De5@N
Message 12 of 17
(2,150 Views)
For Microcontroller programming you have to use C/C++ only, but for communicating from microcontroller to PC u can use serial communication.
labview is having a feature of serial communication.
here my understanding is that you want to see some data coming from microcontroller to PC in labview right?
if that is the case u can do as i said.
Message 13 of 17
(2,141 Views)
No need of DAQ card
Sounds familiar. Smiley Indifferent
Richard
Message 14 of 17
(2,121 Views)
I know...
It motivated me to write something in tbob's old thread.
Kudos to you Broken Arrow.
Message 15 of 17
(2,110 Views)
Hi Jagadesan,
Yes, LabVIEW can be used to program embedded systems..
Checkout this link: http://www.ni.com/embedded/
and from what i understand you are looking for programming 89C51 which is 8-bit uC, LabVIEW is supported only for 32-bit uP/uC and cannot be used to program 89C51 uC..
Rajshekar P
Message 16 of 17
(2,085 Views)
@Raj_NI wrote:
Hi Jagadesan,
Rajshekar P
Not to mention the cost of the latter development system which is quite steep, even for NI system standard
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 17 of 17
(2,077 Views)
