Labview is reading zero from shared variable
Hello everyone
-I have a problem in labview shared variable cause it reads only zero value for all inputs and outputs and timers in S-1200 ...etc
but in NI OPC server using quick client it reads the correct value but when adding them in labview project they are not reading the correct value and only retruing zero
any suggestions
Message 1 of 1
(2,839 Views)
