Labview not reading csv file properly.
It's actually 1.732 if you open the file in Excel.
George Zou
Message 11 of 17
(2,845 Views)
Accepted by dhibbit
See attached VI.
It uses Read Write ASCII-Unicode Text File.vi from the link you gave.
George Zou
Message 12 of 17
(2,843 Views)
Didn't seem to work.
EDIT: Nevermind, I accidentally grabbed the csv file I had already converted back to ASCII.
Message 13 of 17
(2,833 Views)
It's for your original unicode csv file, not for the ASCII version.
George Zou
Message 14 of 17
(2,829 Views)
Yeah, I fixed it.
Thanks for all the help!
(Hopefully Labview integrates Unicode support in the future)
Message 15 of 17
(2,825 Views)
This does not correctly deal with the unicode but will extract the data from this particular file.
It reads the file as binary, removes the first 2 characters (which happen to be the only characters in the fole with values > x7F), then decimates the array. The decimation creates two arrays. One has standard ASCII characters adn the other has all the nulls. Convert the one with ASCII to a string and then to array. Since both string and numeric values are present, it converts both.
Lynn
Message 16 of 17
(2,810 Views)
Kudo to this idea:  Support Unicode
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-Unicode/idi-p/921449
George Zou
Message 17 of 17
(2,789 Views)
