Labview not updating from Arduino input
also check this video https://www.youtube.com/watch?v=J8zw0sS6i1c
about serial communication, and think about the possibiltity to use a end of message character, so you know when you read the serial port, where the message starts and ends. Let's way that the arduino send 2 messages while the computer is doing something else (like acquaring images) and then your serial port will have 2 voltage readings concatenated or half of a message then your data will be lost.
RKO
Message 11 of 13
(774 Views)
You may need to create a parallel loop with the camera.
You were right. I needed a different parallel loop. Now it works perfectly.
Many thanks, you saved me 😉
Message 12 of 13
(769 Views)
You are welcome !
Can u  kudos my answer pls ?
Message 13 of 13
(750 Views)
