Labview pauses when dialog box displayed
When I display a dialog box in LabView, the program waits for the user to click ok. I would like for the program to not wait but keep running after it displays the box. How can I do this and how can I customize the dialog box?
(3,116 Views)
If you don't need the signal generated by the dialog box, then, you can use a subVI for displaying only a pop-up, and including a button to disappear it. Also, if you want only showing a mesage, you can use a string indicator and use a "visible" property (property node) for hidden or showing the mesage. Tell me if you need some extra help...
JFT
(3,116 Views)
I want to use a subVI to display a pop-up and include an ok button to make it disappear. I want the program to keep running after the pop-up appears. Could you post an example on how to do this? Thanks.
(3,116 Views)
You can put the subVI in a separate loop or you can use an Invoke Node (Run VI) and set Wait until done to false.
(3,116 Views)
Just run...
JFT
(3,116 Views)
Could you explain how the invoke node works? I have not used them before.
(3,116 Views)
You drop an Invoke Node from the Application palette onto the block diagram, wire up a reference to the subVI, right click the invoke node and select the method. There's an example here that shows how an invoke node is used to make a front panel visible. There are other examples on the developer zone and several have been posted to this forum. You question seems to pop up once week or so and a little searching of the forum will give you a lot of examples.
(3,116 Views)
