If you don't need the signal generated by the dialog box, then, you can use a subVI for displaying only a pop-up, and including a button to disappear it. Also, if you want only showing a mesage, you can use a string indicator and use a "visible" property (property node) for hidden or showing the mesage. Tell me if you need some extra help...
JFT
