Labview + phidget (ratiometric setting)
Hello there,
I'm working with phidget 1123 precision voltage sensor + Interface Kit 8/8/8  which then the result must be displayed in  LabVIEW. As the sensor in non ratiometric, what is the programming needed to be insert in the labview to indicate the ratiometric state? I use IfGetSensorValue vi to read sensor value. But seems the sensor value is the ratiometric one. I hope there is the solution as the wrong ratiometric setting might result in wrong measurement reading.
Thank you
(4,361 Views)
Accepted by topic author aidasaufi
Quick googling resulted this: Labview Manual IFSetRatio : http://www.phidgets.com/documentation/web/LabVIEWDoc/index.html?ifsetratio.htm
uday
(4,281 Views)
Thank you udka! I never thought that there is funtion for ratiometric state in the library. I should explore further next time. Thank you 🙂
(4,274 Views)
