Labview program fails to close properly!
Place LVWUTIL.llb in user.lib folder.
Change STI.docx to STI.ocx and register the ActiveX control.
Message Edited by Acelhp on 04-10-2008 09:22 AM
Message 21 of 31
(2,220 Views)
Do you have everything you need?
Message 22 of 31
(2,213 Views)
TWGomez
Any luck with your testing?
Message 23 of 31
(2,196 Views)
Sorry I got busy in the lab...
I am going to look at it now...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
Message 24 of 31
(2,191 Views)
Missing LVWUTIL32.dll.
Message 25 of 31
(2,189 Views)
Change extension to dll
Message 26 of 31
(2,184 Views)
Here try this, worked all night and shutdown properly in the AM.
You should move this to a Producer/Consumer (Events) design pattern. I think doing so would clean up the code, make it a little easier to follow, and increase efficiency. Check out "The LabVIEW Style Book" by Blume if you can, great book, helped me tons...
Also the register event callback only needs to be done once, you have it in the loop called every iteration...
I hope it works for you...Cheers!
Message Edited by TWGomez on 04-11-2008 06:29 AM
Message 27 of 31
(2,169 Views)
Thanks for your help, TWGomez.  The new app you sent to me, however, will not open with Labview 8.2.  Any suggestions?
Message 28 of 31
(2,159 Views)
Here is a zip saved in 8.2
Message 29 of 31
(2,155 Views)
Testing is in progress.
Message 30 of 31
(2,147 Views)
