Labview returns a compiler error.
Hey
Labview comes with this error message when I trie to run the VI.
"Compiler error. Report this problem to National Instruments Tech Support.
bad dsoffset, dso= 0"
Appears 12 times.
clocking, no tbl ofst?"
Appears 1 time.
Appears 3 times.
I have tried to remove parts from the block diagram, but the problem seems to go away when removing a random part.
HELP please...
(3,427 Views)
Hey Gubbi,
I believe your errors are on this link: https://www.ni.com/en/support/documentation/bugs/08/archived--labview-8-5-x-known-issues-by-date.htm...
Search for them and try to solve them.
Tell me if it works.
TN
Currently using LV 8.5
logo
(3,415 Views)
Hurra hurra... Problem solved!
I didn't find the problom in the "Known Issues" list.
But there where alot of places there the Workaround was "Insert always copy function".
So i tried to insert it on all wires, and finally on on wire the problem was solved! (Se attachment)
Thanks!
Ps. any one knows why this error occours please let me know, I'm quit curious!
(3,407 Views)
Glad it's solved. About, why that happens, i don't know it too..
TN
logo
(3,403 Views)
