03-14-2024 04:11 PM
Hi, everyone.
I have never used labview or any software related to that till the begging of this year, so I'm completely lost about how to find a proper solution for my problem.
Here it goes:
Some years ago, a professor (now retired) made software to make it easier to run an analysis.
The software plots data from a spreadsheet into a x,y graph and make it easier to visualize and estimate the "shape" of our data.
Bellow is the example of how it looks
It runs perfectly fine on the computer it was installed first.
However, we needed to have more computers with this software. I got in touch with the professor, who told me I only needed labview runtime engine 2020 or 2019.
I got it, installed on two computers, but one of them is working fine just as expected, but on the other, it just loads the "header" of the data, but not columns for the graphics
Same data, installed using the same source, in the same way, but:
I reinstalled labview, opened it as adm, tried to look into the specs of the computers to find something different, and updated windows c+++, with no success.
I would like to know if anyone guess what could be causing this problem, or something I am trying to figure out what is different between the computers that are making the software run on one but do not run on another.
Thank you, everyone!
Solved! Go to Solution.
03-14-2024 05:01 PM
LabVIEW sometimes can call external programs to run code made for them originally. MATLAB and Python are two specific examples, but there could be something more specialized that it's trying to check as well.
Can you check and see what other software is installed on the two working PCs that is missing from the non-working PC?
If you have access to the source code of the original application before it was made into an EXE there are ways to check it, but it sounds like you don't have that?
03-14-2024 06:12 PM
I checked and I couldn't find anything different. They do not have Matlab or Phyton. The only difference I could find between the two of them is that the one running has dedicated video graphics while the other doesn't, although it's odd to think about that being something because that's not graphically demanding 😕
03-14-2024 06:21 PM - edited 03-14-2024 06:22 PM
Something else I just noticed is that based on the appearance of the software, it looks like it might be set to use a comma as a decimal separator instead of a period. If it's set to read from a file or device and this is reversed, it can read just part of it but not the rest of it.
Can you check the settings of all the PCs for this? You will find it in the Control Panel, under the Region settings, under "Additional settings".
If the two working PCs are set one way and the nonworking one is set to another, that's probably it.
03-14-2024 06:34 PM
Just checked on both computers and they look the same 😞
03-14-2024 09:00 PM
Judging by the picture that you showed, it appears that the data being analyzed are saved as Excel files. That suggests that the LabVIEW code may be utilizing the Report Generation Toolkit, which has links to Excel. Do the computers you are trying to use have Excel installed? Microsoft, unfortunately, has the habit of making little changes to Excel that requires some "manual" adjustments to the RGT in order to work.
I would approach your now-retired Professor and politely request the LabVIEW routines, which you can use to "resurrect" the analysis routines he developed while a faculty member. Note that you will need to obtain a working LabVIEW development system (meaning a PC with a licensed version of LabVIEW, and someone with LabVIEW expertise to install the University's software that your Professor developed while an employee and to get it working again for you.
For what it is worth, copies of software I've developed wherever I've been have been available for my colleagues to continue to use after I depart. On occasion, I've been contacted for copies from former colleagues who have also moved to new locations, and have happily complied ...
03-15-2024 07:24 AM
Check date format also, that's a common issue.
You know what the similarity between Excel and a stalker is? Both makes the wrong assumption of what's a date! 😄
03-15-2024 09:24 AM
OMGGGGG IT IS WORKING
That joke about excel solved a 3-month long issue...
I use on my computer day-month-year, when I changed to month-day-year it worked! I can't believe it was something so DUMB
I would NEVER expect that to be the problem.
Thank you so much 🙏 💛
03-15-2024 09:36 AM
You're welcome. Yeah, dates and time zones have been the bane of many programs for 50 years. 🙂
03-15-2024 10:10 AM
Yeah, it's crazy how EVERYONE else in the world thinks that dates should be expressed in a logical day, month, year format. Here in the good 'Ol USA we know better! 🙃
