Labview tcp comm with siemens 300 plc
Maybe you would like to explain the changes you made to make it work. It would be tremendously helpful for others who might face the same problem.
Message 11 of 14
(835 Views)
Hi
I used the sample VIs " S7Com_2009_11_06.zip"(you posted the link) and changed the lenght then it works.
Message 12 of 14
(832 Views)
Hi Sir,
For siemens smart PLC, the same method, right ?
Could you share your PLC side setting(the pic is not able to see) and the "S7Com_2009_11_06.zip" ?
Thanks very much.
Learning from other people
Message 13 of 14
(601 Views)
Already find it from that previous link, thanks.
S7 PLC TCP/IP Protocol Reference Example - NI Community
Message 14 of 14
(589 Views)
