Labview vi for characterizing MOSFET (I-V curves) using Keithley 26xx series
Hello
I am looking for vi for characterizing mosfet (3 terminal I-V curves) using Labview and Keithley 2602A. I am new to labview so I am not sure if there is a some kind of repository where people upload their vi or how to I find the vi modules.
I would like to keep the 2 terminals (source and drain) voltage constant and measure current through the drain, while sweeping a range of voltage from the 3rd terminal (gate). It is exactly like a typical mosfet transfer curve.
I am not expecting direct answers, but may be hints or help where I can find them or how should I look for them.
thanks
(3,604 Views)
Accepted by fall13vox
Hi vox,
as you are new to LabVIEW you surely noted the "Getting started" section on top of the LabVIEW discussion forum.
Yes, there is some kind of repository: see the InstrumentDriverNetwork
This will help you to control your external device using LabVIEW.
All you need to do is to program your required measurement steps… 😄
(3,595 Views)
