Large Block diagram cleanup problem
Seeing a strange behavior in my project.I can't see any of my shift register nodes on the while loop. Some of them disappeared when I used the block diagram cleanup tool. My block diagram spans to two monitors width and is pretty complex. Is there any solution to this? Also are there any third party plugins that is solely utilized to clean up the code? The clean up doesn't seem to be working for large block diagrams.
NI System Configuration:
- NI PXIe-1071, 4-Slot 3U PXI Express Chassis , 1 GB/Slot throughput, Part Number: 781368-01
- NI PXIe-PCIe8381,x8 Gen2 MXI-Express for PXI Express Interface,3m, Part Number: 782522-01
- PXIe-5160 PXI Oscilloscope, 500 MHz, 10 bits, 2.5 GS/s, 2 Channels, 64 MB, Part Number: 782621-01
- Astronics PXIe-1209 2-Channel, 100 MHz PXI Pulse Generator, Part Number: 785033-01
(5,560 Views)
Posting your code would be the best way to get help. It looks like from the one picture that you did post that the part you showed the vi is covered by the loop. Try to open the loop to see if things are covered up. There is also a setting in LabVIEW that will show covered items.
Tim
GHSP
(5,553 Views)
That's the problem. I can't post the code. Could you please tell me about the setting in LabVIEW? I am using 2019 version if that's of any help.
(5,546 Views)
You have two problems:
  1. You used the block diagram cleanup tool.  Never do that; it just makes things worse.
  2. You got an obscenely large block diagram (don't do that either).
(5,541 Views)
I always say, "If the block diagram cleanup tool makes your code look better, then you're doing it wrong."
Bill
CLD
(Mid-Level minion.)
(5,533 Views)
Ctrl-L
Click the "Show Warnings" box.
(5,464 Views)
Accepted by asukumari
With regards to that bit, you might find the tools to create subVIs from selections of code useful (Edit > Create SubVI).
If your code is large and complicated, your first step should be trying to reduce the local complexity - make it possible to identify which bits do what.
SubVIs with suitable names and icons will make it much less complicated to understand, whilst conveniently also reducing block diagram size (for a single VI - the total may well increase depending on if the subVIs are repeatedly called or not).
(5,402 Views)
