Large(ish) Remote Panel Applications?
I'm just wondering if anyone has had any luck developing Medium to Large scale remote panel applications and would be willing to share their experiences.
I ask because I'm in the process of developing an application that I intend to be deployed remotely, and have already run in to two major bugs (that got sent to NI R&D) requiring workarounds, and one plugin (the LAVA GUI plugin) that just causes LabVIEW on the client computer to hard crash... and I'm 30% done with the application.  At this point in time, I am seriously considering bailing on the remote panels and trying to come up with an alternate way to deploy the app.
Thoughts?
(3,664 Views)
First, a question. What are the system constraints? What exactly are you trying to accomplish?
Mike..
Certified LabVIEW Architect
LabVIEW Champion
(3,648 Views)
Mike..
Without going in to needless detail... the constraint is that I need remote access to the application.  The computer attached to the hardware will be in a different physical location than the operator running the program.
Yes, there are a lot of other solutions I can explore (TCP/IP communication, remote desktop applications like RAdmin, etc), but the path I chose to pursue initially was Remote Panels because it seemed the simplest to implement, while solving several other problems - such as preventing the users from ever having direct access to the data they acquire.
(3,638 Views)
You could access the remote application via VI Server. This is a little higher level access than TCP/IP and wouldn't constrain your interface to what you happen to have running on the remote computer.
This may be just me, but I don't think I would want to be running to a remote location because the GUI for my local system needed to change.
Mike...
LabVIEW Champion
(3,626 Views)
Thanks for the advice. I have considered several options. The application is already using VI server (not web based) being run from a remote location. It still has errors - which brings me back to my original question:
Does anyone have experience with this that they would like to share?
Mike...
Edit:  Clarify that a little if you could?  I'm running remotely because the computer and hardware are at a remote location...
(3,615 Views)
