Timmer to extend a boolean input
I have a boolean False for 29 seconds and True for 1 second, this is basically a Strobe input to a DAQ DI/O and when I'm receiving the strobe I want to keep the LED on the VI On(green) for 25 seconds and then it will be off for about 4 seconds until the next strobe hits.
Can I do this with a simple Nand latch and one of the timers? I can't seem to find a timer that has a boolean output which I found to be strange but there should be a simple way to do this "pulse streching"
Thanks for any help in advance
(3,719 Views)
Have you looked at the Elapsed Time function?
(3,707 Views)
There are lots of ways to do it. It all depends on what the rest of your program looks like. (hint, hint)
Mike
Certified LabVIEW Architect
LabVIEW Champion
(3,683 Views)
Do you want the vi or just an image of the circuit?
(3,656 Views)
How 'bout one of each. You can't troubleshoot pictures, but you can't see VIs on smart phones.
Mike...
LabVIEW Champion
(3,653 Views)
